Bamboo Build - zip source code
Todd Ellner
We have Bitbucket server project which we would like to deploy on a CI/CD basis through Bamboo. It doesn't need a regular build. Bamboo just needs to create an artifact by zipping up the source code and firing off the deployer. Will this require adding a new capability?
3 votes
Timothy
July 11, 2016
No. This should be a simple end to end setup for Bamboo. Bamboo has the checkout source code and script task to zip the file. Maybe you'll need an SCP to copy the files over the to the server but that's about it.
