Bamboo CLI
Saugat Chowdhury December 11, 2017
Is there a way to set up project level permissions through Bamboo CLI or any other way to set permission remotely instead of doing it from the UI?
I think Bamboo REST API currently does not support any write operation.
Is it possible to develop a plugin for that?
Grzegorz Lewandowski
December 11, 2017
You can use those REST endpoints to achieve what you want:
https://docs.atlassian.com/atlassian-bamboo/REST/6.2.5/#d2e4367
https://docs.atlassian.com/atlassian-bamboo/REST/6.2.5/#d2e44
In 6.2. permissions rest endpoints were unified and support all CRUD operations.
Saugat Chowdhury December 12, 2017
thanks it is useful.
I was trying this to set project level permission for an user - https://docs.atlassian.com/atlassian-bamboo/REST/6.2.5/#d2e4393
PUT /permissions/project/{key}/users/{name : (.+)?}
Where the permission (e.g. ADMIN/CREATE) should be specified? hopefully as payload, any sample?
btw, Don't see REST API to create a Build Project though?
December 13, 2017
AFAIR, there's no endpoint to create a project.
The permissions payload should be in the request body, e.g.
["BUILD","READ"]
If you need more examples, you can navigate to any permissions widget (e.g project or plan permissions) in Bamboo and use browser console to lookup requests that are being sent. Those use the same set of REST endpoints.
Saugat Chowdhury December 13, 2017
thanks...
