We are using Bamboo Version 6.4.0. We have 6 Environments in a Bamboo Deployment Plan as shown below
Env1
Env2
Env3
Env4
Env5
Env6
We want Env6 to be executed only after Env1 thru Env5 are successfully deployed.
We set the Triggers accordingly ( After Successful deployment of Env1 thru Env5).
This setup seems not working if any of the Dependent enviroments ( Env1 thru ENV5) fails.
Can someone suggest a work around for this?.
Rajath,
Thank you so much for your reply. I think you din't understand our situation.Let me explain you our situation one more time.
We have Bamboo Deployment Plan which has 6 deployment environments ( Env1 , Env2 ,Env3, Env4 , Env5 and Env6 ).
We want Env6 to deployed only if all of the depending Environments ( Env1 , Env2 ,
Env3, Env4 , Env5 ) are deployed successfully.
We setup the Triggers for Env6 accordingly ( After Successful deployment of Env1 thru Env5 ).We were expecting Env6 will be deployed only once ( when all of the Env1 thru Env5 are deployed successfully.
But the problem is sometimes Env6 is being deployed 5 times which means , Env6 is being deployed immediately after Env1 , Env2 ,Env3, Env4 , Env5 are deployed.
Venkat,
If Env6 is deploying five times, I guess you have given 5 triggers for it to trigger. That is not the ideal case. If you want to trigger Env6 only after all the other environments are successful, you should follow the method like I said.
Your method (assumption) :
Triggers in Env6 : Env1 , Env2 ,Env3, Env4 , Env5
This will result in triggering Env6 everytime one of the Env1 - Env5 are successful making 5 deployments for Env6
Correct way :
Triggers in Env2 : Env1
Trigger in Env3 : Env2
Trigger in Evn4 : Env3
Trigger in Env5 : Env4
Trigger in Evn6 : Env5
This way Env6 will trigger only after all the first 5 Env are successful. Also if any of the first 5 fails it`ll stop the flow and Env1 can be triggered manually or by the bamboo plan providing artifacts to it.
Hope this helps.
Rajath
Hi Venkat,
You can have a After Successful deployment trigger in each environment with the triggering environment being the previous environment as shown below :
If you have three environments dev, qa , prod. Configure triggers only in qa and prod with triggering environment as below :
dev <- can be triggered from bamboo plan or can be manual
qa <- dev ( triggered by dev deployment once it is success )
prod <- qa ( triggered by qa deployment once it is success )
Do not create multiple triggers like below :
qa <- dev
prod <- dev , qa
By doing so , prod will trigger in cases dev is successful but qa failed.
Hope this helps.
Rajath
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗Online forums and learning are now in one easy-to-use experience.
