hi
in my bamboo project i have JUnit parer where all Jnuit Report Errors will be displayed via.
The XML is in UTF-8 Format <?xml version="1.0" encoding="UTF-8" ?>
Problem: in Bamboo Plan the UFT 8 is not working..
This is what i wanna see:
expecting [中国河北省邢台市南宫市], actual was [中国河北省邢台市]
This is what i see in my Report ERROR in bamboo:
[Match content of [Label]] XPathContains comparison failed, expecting [????], actual was [??????‚]
Any ideas whats wrong??
hi
change did not work.. still have the same problem!
expecting [????], actual was [??????‚] in Error Log
It seems that you encountered issue, where the file encoding is not passed through the parameter in Bamboo. There was a similar case before and adding an encoding parameter into <BAMBOO_INSTALL>/conf/wrapper.conf file seems to solve the problem. Here's the parameter that you need to add.
wrapper.java.additional.X=-Dfile.encoding=utf-8
Please bear in mind that the "X" is the number that is after the last number on the parameter passing on the same file, and please restart Bamboo Server after doing this. For more information please refer to this knowledge base article.
If it didn't help, you might need to add this parameter to the remote agent as well (inside <AGENT_HOME>/conf/wrapper.conf file). After making changes, you have to restart the remote agent just like the Bamboo Server.
