I get the following error when browsing a build in bamboo, note that this only happens once a 'Release' is created for this particular build in the 'Deployment' tab for the project:
com.google.template.soy.tofu.SoyTofuException: In template bamboo.feature.deployment.build.relatedVersions: When evaluating "not $environmentStatus.deploymentResult and not $environmentStatus.latestResult or $environmentStatus.deploymentResult and not $environmentStatus.latestResult and $environmentStatus.deploymentResult.deploymentState == 'FAILED' or $environmentStatus.latestResult and compare_date($environmentStatus.latestResult.deploymentVersion.creationDate, $relatedVersion.creationDate) < 0": Error while computing function "compare_date($environmentStatus.latestResult.deploymentVersion.creationDate, $relatedVersion.creationDate)": Non-string found when expecting string value.
See screenshot and full stack trace below.
com.google.template.soy.tofu.SoyTofuException: In template bamboo.feature.deployment.build.relatedVersions: When evaluating "not $environmentStatus.deploymentResult and not $environmentStatus.latestResult or $environmentStatus.deploymentResult and not $environmentStatus.latestResult and $environmentStatus.deploymentResult.deploymentState == 'FAILED' or $environmentStatus.latestResult and compare_date($environmentStatus.latestResult.deploymentVersion.creationDate, $relatedVersion.creationDate) < 0": Error while computing function "compare_date($environmentStatus.latestResult.deploymentVersion.creationDate, $relatedVersion.creationDate)": Non-string found when expecting string value. at com.google.template.soy.tofu.internal.BaseTofu.renderMainHelper(BaseTofu.java:341) at com.google.template.soy.tofu.internal.BaseTofu.renderMain(BaseTofu.java:300) at com.google.template.soy.tofu.internal.BaseTofu.access$100(BaseTofu.java:56) at com.google.template.soy.tofu.internal.BaseTofu$RendererImpl.render(BaseTofu.java:427) at com.atlassian.soy.impl.DefaultSoyManager.render(DefaultSoyManager.java:112) at com.atlassian.soy.impl.SoyTemplateRendererImpl.render(SoyTemplateRendererImpl.java:40) at com.atlassian.soy.impl.SoyTemplateRendererImpl.render(SoyTemplateRendererImpl.java:33) at com.atlassian.soy.impl.SoyTemplateRendererImpl.render(SoyTemplateRendererImpl.java:26) at sun.reflect.GeneratedMethodAccessor255.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.atlassian.bamboo.plugin.OsgiServiceProxyFactoryImpl$DynamicServiceInvocationHandler.invoke(OsgiServiceProxyFactoryImpl.java:155) at com.sun.proxy.$Proxy848.render(Unknown Source) at com.atlassian.bamboo.ww2.BambooFreemarkerManager$SoyHelper.renderNoCache(BambooFreemarkerManager.java:768) at com.atlassian.bamboo.ww2.BambooFreemarkerManager$SoyHelper.render(BambooFreemarkerManager.java:755) at sun.reflect.GeneratedMethodAccessor677.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:805) at freemarker.ext.beans.OverloadedMethodModel.exec(OverloadedMethodModel.java:105) at freemarker.core.MethodCall._getAsTemplateModel(MethodCall.java:104) at freemarker.core.Expression.getAsTemplateModel(Expression.java:89) at freemarker.core.Expression.getStringValue(Expression.java:93) at freemarker.core.DollarVariable.accept(DollarVariable.java:76) at freemarker.core.Environment.visit(Environment.java:210) at freemarker.core.MixedContent.accept(MixedContent.java:92) at freemarker.core.Environment.visit(Environment.java:210) at freemarker.core.ConditionalBlock.accept(ConditionalBlock.java:79) at freemarker.core.Environment.visit(Environment.java:210) at freemarker.core.MixedContent.accept(MixedContent.java:92) at freemarker.core.Environment.visit(Environment.java:210) at freemarker.core.Environment.process(Environment.java:190) at freemarker.template.Template.process(Template.java:289) at freemarker.template.Template.process(Template.java:243) at com.atlassian.bamboo.ww2.BambooFreemarkerManager.renderText(BambooFreemarkerManager.java:583) at com.atlassian.bamboo.plugin.web.FreemarkerWebPanelRenderer.render(FreemarkerWebPanelRenderer.java:98) at com.atlassian.plugin.web.model.ResourceTemplateWebPanel.writeHtml(ResourceTemplateWebPanel.java:50) at com.atlassian.plugin.web.model.ResourceTemplateWebPanel.getHtml(ResourceTemplateWebPanel.java:65) at com.atlassian.plugin.web.descriptors.DefaultWebPanelModuleDescriptor$ContextAwareWebPanel.getHtml(DefaultWebPanelModuleDescriptor.java:143) at com.atlassian.bamboo.ww2.FreemarkerContext.getWebPanels(FreemarkerContext.java:522) at com.atlassian.bamboo.ww2.FreemarkerContext.getWebPanels(FreemarkerContext.java:506) at sun.reflect.GeneratedMethodAccessor757.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:805) at freemarker.ext.beans.OverloadedMethodModel.exec(OverloadedMethodModel.java:105) at freemarker.core.MethodCall._getAsTemplateModel(MethodCall.java:104) at freemarker.core.Expression.getAsTemplateModel(Expression.java:89) at freemarker.core.IteratorBlock.accept(IteratorBlock.java:94) at freemarker.core.Environment.visit(Environment.java:210) at freemarker.core.Macro$Context.runMacro(Macro.java:183) at freemarker.core.Environment.visit(Environment.java:603) at freemarker.core.UnifiedCall.accept(UnifiedCall.java:118) at freemarker.core.Environment.visit(Environment.java:210) at freemarker.core.MixedContent.accept(MixedContent.java:92) at freemarker.core.Environment.visit(Environment.java:210) at freemarker.core.Environment.process(Environment.java:190) at freemarker.template.Template.process(Template.java:289) at freemarker.template.Template.process(Template.java:243) at com.opensymphony.webwork.views.freemarker.FreemarkerResult.doExecute(FreemarkerResult.java:214) at com.opensymphony.webwork.dispatcher.WebWorkResultSupport.execute(WebWorkResultSupport.java:143) at com.opensymphony.xwork.DefaultActionInvocation.executeResult(DefaultActionInvocation.java:313) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:208) at com.opensymphony.xwork.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:175) at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor.validateWorkflow(BambooWorkflowInterceptor.java:53) at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor.access$000(BambooWorkflowInterceptor.java:16) at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor$1.call(BambooWorkflowInterceptor.java:33) at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor$1.call(BambooWorkflowInterceptor.java:29) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor.doIntercept(BambooWorkflowInterceptor.java:28) at com.opensymphony.xwork.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:86) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.validator.ValidationInterceptor.doIntercept(ValidationInterceptor.java:116) at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor.validate(BambooValidationInterceptor.java:48) at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor.access$000(BambooValidationInterceptor.java:12) at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor$1.call(BambooValidationInterceptor.java:28) at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor$1.call(BambooValidationInterceptor.java:24) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor.doIntercept(BambooValidationInterceptor.java:23) at com.opensymphony.xwork.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:86) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.FieldErrorUsageVerifier.intercept(FieldErrorUsageVerifier.java:48) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.JSONValidationInterceptor.doIntercept(JSONValidationInterceptor.java:69) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.SimpleConversionErrorInterceptor.intercept(SimpleConversionErrorInterceptor.java:78) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.webwork.interceptor.FileUploadInterceptor.intercept(FileUploadInterceptor.java:174) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.I18nInterceptor.intercept(I18nInterceptor.java:151) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.security.acegi.intercept.web.WebworkSecurityInterceptor.intercept(WebworkSecurityInterceptor.java:54) at com.atlassian.bamboo.security.acegi.intercept.web.WebworkSecurityInterceptorProxy.intercept(WebworkSecurityInterceptorProxy.java:30) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.OnDemandNotSupportedInterceptor.intercept(OnDemandNotSupportedInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.PaginationAwareInterceptor.doIntercept(PaginationAwareInterceptor.java:98) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.StatisticsAwareInterceptor.doIntercept(StatisticsAwareInterceptor.java:38) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.ResultsListAwareInterceptor.doIntercept(ResultsListAwareInterceptor.java:41) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.NavigationAwareInterceptor.doIntercept(NavigationAwareInterceptor.java:117) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.BuildResultsSummaryAwareInteceptor.doIntercept(BuildResultsSummaryAwareInteceptor.java:70) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.ResultsSummaryAwareInteceptor.doIntercept(ResultsSummaryAwareInteceptor.java:72) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.atlassian.bamboo.ww2.interceptors.ChainAwareInterceptor.doIntercept(ChainAwareInterceptor.java:111) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32) at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49) at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.interceptor.ExceptionMappingInterceptor.intercept(ExceptionMappingInterceptor.java:186) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190) at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:116) at com.opensymphony.webwork.dispatcher.DispatcherUtils.serviceAction(DispatcherUtils.java:274) at com.opensymphony.webwork.dispatcher.FilterDispatcher.doFilter(FilterDispatcher.java:202) at com.atlassian.bamboo.ww2.BambooFilterDispatcher.doFilter(BambooFilterDispatcher.java:20) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.bamboo.filter.SessionCreationForAnonymousUserFilter.doFilter(SessionCreationForAnonymousUserFilter.java:60) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.bamboo.filter.NewRelicTransactionNamingFilter.doFilter(NewRelicTransactionNamingFilter.java:31) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.bamboo.ww2.ValidActionContextMarker.doFilter(ValidActionContextMarker.java:37) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.opensymphony.webwork.dispatcher.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:88) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.bamboo.filter.BambooProfilingFilter.doFilter(BambooProfilingFilter.java:44) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.bamboo.filter.AccessLogFilter.doFilter(AccessLogFilter.java:66) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at com.atlassian.bamboo.filter.SeraphLoginFilter.doFilter(SeraphLoginFilter.java:71) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at com.atlassian.bamboo.filter.BambooAcegiProxyFilter.doFilter(BambooAcegiProxyFilter.java:25) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.bamboo.filter.LicenseFilter.doFilter(LicenseFilter.java:73) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150) at com.atlassian.seraph.filter.BambooLoginFilter.doFilter(BambooLoginFilter.java:34) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:55) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170) at com.atlassian.bamboo.persistence.BambooSessionInViewFilter.doFilterInternal(BambooSessionInViewFilter.java:36) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.planetj.servlet.filter.compression.CompressingFilter.handleDoFilter(CompressingFilter.java:203) at com.planetj.servlet.filter.compression.CompressingFilter.doFilter(CompressingFilter.java:193) at com.atlassian.bamboo.filter.CompressingFilter.doFilter(CompressingFilter.java:71) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.bamboo.filter.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:28) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:32) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:477) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119) at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:542) at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:227) at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1031) at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:406) at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:186) at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:965) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117) at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:288) at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:115) at com.atlassian.bamboo.filter.UrlRewriteFilter.forwardTo(UrlRewriteFilter.java:307) at com.atlassian.bamboo.filter.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:182) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:96) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331) at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:477) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119) at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524) at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:227) at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1031) at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:406) at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:186) at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:965) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117) at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111) at org.eclipse.jetty.server.Server.handle(Server.java:349) at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:452) at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:884) at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:938) at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:634) at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230) at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77) at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:609) at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:45) at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:599) at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:534) at java.lang.Thread.run(Unknown Source)
Error seems to have gone away now, its a few days later so I imagine the machine has been restarted again in the meantime. No new installs that I'm aware of.
Is this a new installation? from the error you are getting, it appears like the unzipping/unarchiving tool has corrupted some files or is incompleted. If this is a new installation, I will suggest that you try to re-install again. Regards
Sultan
