Bamboo Plan Variables not working for me
Eric Hood May 23, 2016
I am having trouble making use of Plan Variables in Bamboo.
I added a plan variable, name: stuff, value: 1.2.3
In my "Default Job", I have a Script (File) task calling a command line utility, passing in a few parameters, including: ${bamboo.stuff}
Unfortunately, what is being passed is "${bamboo.stuff}", not "1.2.3"
Other built in bamboo properties are being passed in just fine, just not my plan variable.
I've tried: ${stuff}, $stuff, $bamboo.stuff, ${bamboo_stuff}, %STUFF%, %BAMBOO_STUFF%, and others, but I can't get it to respond.
What am I doing wrong?
SidduAngadi
If it is Unix  — you should call ${bamboo.stuff}
windows -   %bamboo.stuff%
within java -   bamboo_stuff
These all worked for me.
If above does not worked, send me the version of bamboo, platform on which it is running and screenshot of variable and script.
Siddu
Eric Hood May 24, 2016
Sorry, forgot to mention I'm in Windows.
The Script Task uses File as its location, and as an example of my Argument value:
-root="${bamboo.build.working.directory}" -test=${bamboo.stuff} -revision=${bamboo.repository.revision.number}
What I get passed to me, root and revision are replaced correctly.  But for test ==> ${bamboo.stuff}
Bamboo 5.11.1.1 (but still in trial-mode)
rverschoor
May 24, 2016
Using ${bamboo.stuff} will only work if you use the Script Task with an inline script.
Bamboo will replace any variable references it sees there before it starts running the script.
If you let the Script Task with the script in a file, Bamboo will not get a chance to replace the variables.
So one solution would be to use an inline script instead of a file.
If you need to stick to a file script, you need to use the environment variables that Bamboo creates.
In your case you should be able to reference the variables with %BAMBOO_STUFF%.
You wrote that you already tried that, but it didn't work.
To investigate this, you can add a simple Script Task that just calls "set".
In the build log you can then see all environment variables.
I tried your SET idea, and though it listed out nearly 100 items, "stuff" is nowhere in the list.  sad
ZillaYT May 22, 2017
For Linux style inline script, the ${bamboo.stuff} syntax did NOT work for me, that is when I do the following in my inline script
STUFF=${bamboo.stuff}
I get...
${bamboo.stuff}: bad substitution
