I've got a remote agent running on Linux that I use a custom bamboo-capabilities.properties file in the agent's bin directory to define numerous capabilities local to the agent. This seems to work fine. I can't locate it at the moment, but previously saw documentation somewhere that said if you want to do this, and prevent Bamboo agent from automatically detecting capabilities to use a switch in the wrapper.conf of the agent like this :
wrapper.java.additional.4=-DDISABLE_AGENT_AUTO_CAPABILITY_DETECTION=true
When I view the agent in the Bamboo Admin agent panel it detects an old Ant install at /usr
I delete this capability from the admin agent page and add this to bamboo-capabilities.properties :
system.builder.ant.Ant=/opt/tools/apache-ant-1.8.3
and restart the agent. Yet it resets the "Ant" capability to /usr and not to the custom defined option.
Is using DISABLE_AGENT_AUTO_CAPABILITY_DETECTION correct? Am i missing something else?
Environment :
Bamboo 4.1 : JDK 1.6 and Linux for both Bamboo and agents.
Hi Adam,
Thanks for the d info and detailed test. I have actually faced this issue recently and it appears the -DDISABLE_AGENT_AUTO_CAPABILITY_DETECTION=true property should be added to the Bamboo server and not the agent. This is a kind of misunderstanding. place it in the wrapper.conf file of bamboo server and restart both server and agent and see if it works.
Yup, that did it. I set that property in the SERVER's wrapper.conf, restarted Bamboo, then deleted the capabilities for agent3 and restarted the agent. The capabilities were NOT auto detected.
That being said I think there is value to having the flag at the server level, but also HUGE value to having it at the AGENT level. If you're running 25-100 remote agents (we run 100) we have multiple teams running agents and some want auto-detected capabilities and don't care to manage them; other teams want explicit control of the capabilities defined on their agents they operate and want NO auto-detection. I'm going to log a Jira request improvement for this. Thanks for following up.
You are most welcome Adam and I cant agree more than that. Please do paste the improvement request URL here for future reference by other users
Hi Adam,
Can you try another approach of re-installing the agent with this command:
java -Ddisable_agent_auto_capability_detection=
true
-jar atlassian-bamboo-agent-installer-
2.2
-SNAPSHOT.jar http:
//bamboo-host-server:8085/agentServer/
Sultan - the flag doesn't make a difference. I am now trying on Bamb00 4.4.
I installed a remote agent (agent1) as a control without any special flags. It started and showed up in the agent list and had fully detected the JDK, GIT, etc I had on my system, as expected.
I installed a remote agent (agent2) passing the flag you mentioned, -Ddisable_agent_auto_capability_detection=true
The agent installed and started fine, showed up in the agent list, but it also had fully detected all my system's capabilities. I looked in the wrapper.conf and it did NOT have the flag anywhere specified in it.
I installed a remote agent (agent3) passing the flag on the command line as you mentioned, and then going into the agent3's wrapper.conf and manually adding :
wrapper.java.additional.3=-DDISABLE_AGENT_AUTO_CAPABILITY_DETECTION=true
to ensure it was there. I then started that agent3 fore the first time and went into admin agent section. Viewing the agent I can see it too auto detected all the capabilities. As a test, I manually used the Delete link to delete all the capabilities then restarted the agent3. After restart it still auto-detected all the capabilities.
I then used the command line install process to run a new remote agent (agent4) but did NOT pass the 'install' or 'installntservice' flag so that the agent would start and DID pass the -DDISABLE_AGENT_AUTO_CAPABILITY_DETECTION=true flag on that same command line. The agent started as expected and in the agent details I could it too fully auto detected the capabilities.
All this testing was done on Windows 7, but I have observed this with Bamboo running on Windows Server 2008 with Agents installed both on Windows 2008 and Linux. Seems the flag in general doesn't work.
Jira Improvement Ticket : https://jira.atlassian.com/browse/BAM-12894
Learn more
