Bamboo: SSL issues after CentOS upgrade
Martin Mielke
December 7, 2020
Dear all,
Bamboo stopped accepting connections on port 8443 after the last OS upgrade we did a few days ago.
Nmap shows this:
---] START OF PASTED TEXT
PORT STATE SERVICE
8443/tcp open https-alt
| ssl-enum-ciphers:
| TLSv1.0:
| ciphers:
| TLS_DHE_RSA_WITH_AES_128_CBC_SHA (dh 2048) - A
| TLS_DHE_RSA_WITH_AES_256_CBC_SHA (dh 2048) - A
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (secp256r1) - A
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (secp256r1) - A
| compressors:
| NULL
| cipher preference: client
| TLSv1.1:
| ciphers:
| compressors:
| NULL
| TLSv1.2:
| ciphers:
| TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 (dh 2048) - A
| TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 (dh 2048) - A
| TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 (dh 2048) - A
| TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 (dh 2048) - A
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (secp256r1) - A
| TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (secp256r1) - A
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (secp256r1) - A
| TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (secp256r1) - A
| compressors:
| NULL
|_ least strength: A
---] END OF PASTED TEXT
And curl shows this:
$ curl -v https://bamboserver:8443
* Rebuilt URL to: https://bamboo.server:8443/
* Trying 192.168.0.10...
* TCP_NODELAY set
* Connected to bamboo.server (192.168.0.10) port 8443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS alert, illegal parameter (559):
* error:141BD06C:SSL routines:tls_parse_stoc_key_share:bad key share
* Closing connection 0
curl: (35) error:141BD06C:SSL routines:tls_parse_stoc_key_share:bad key share
Any ideas as to why connections to port 8443 yield messages like: "ERR_SSL_PROTOCOL_ERROR" on Google Chrome? Similar ones show with Firefox as well.
Is there any way to fix it?
Thanks and regards,
Martin
Daniel Ebers
December 11, 2020
Hi Martin,
are you using a reverse proxy in front of Bamboo or what is exactly terminating the SSL connections?
As you mentioned an OS upgrade I rather suspect that something was updated and is not imcompatible (needs probably a fix of one configuration line or the other).
But I rather suspect this to be an Apache/nginx then Bamboo itself (except you touched Bamboo installation as well).
Are the certificate files still in the proper location, intact and readable?
I ask because of:
Daniel
Martin Mielke
December 11, 2020 edited
Hi Daniel,
thanks for your reply.
There are no reverse proxies.
I solved this issue through the Atlassian Support.
We were hit by a known issue:  https://jira.atlassian.com/browse/BAM-21157
This thread can be closed.
Best,
Martin
