How do I go about attaching new plans to existing projects?
At the moment I'm getting:
Exception in thread "main" com.atlassian.bamboo.specs.api.exceptions.BambooSpecsPublishingException: An error occurred while publishing plan APN-MODULES: Duplicate project name modules
thrown, which technically makes sense as that project does already exist.
I can't find anything in the reference API or Java docs for how to create a plan on a project that has already been created.
The method I'm using to create a new plan:
public static Plan createPlan(String planName, String planKey, String planDescription, String projectName, String projectKey) { Project project = new Project() .name(projectName) .key(projectKey); return new Plan(project, planName, planKey) .description(planDescription); }
Any help is much appreciated.
To add plans to an existing project you must set the OID on the project object.
.oid(new BambooOid("<PROJECT_OID>"))
You can get the OID by viewing an existing plan in the project "as Java specs".
That is observed to be true for Bamboo 6.4.1, but not necessary for newer versions of Bamboo like 6.6.1 (which is the one I tested).
Verified. I've removed the OID from the project object on Bamboo 6.7.2 and the spec was successful.
I am on Bamboo 6.6.3 and it works fine without specifying the OID.
On 6.5, I was able to use an existing plan by using name, key, and oid:
Project project() {
return new Project()
.name("project_name")
.key("project_key")
.oid(new BambooOid("project_oid"));
Are you sure you didn't make mistake in project key?
What happens if you skip .name(projectName) from project definition? (it should work if project with given key already exists)
@Marcin GardiasI'm having the same issues as @turnerc. If I create a Project object using an existing name and key then I get a "Project with this name already exists" error. I'm on Bamboo 6.4.1.
If I do not set the ".name" of the Project object, per your suggestion, I get a "Please enter a project name" error.
Is it possible to use Bamboo specs with an existing Bamboo project?
