I'm creating a bamboo.yml with 2 plan and I want to reuse this code as YALM anchors.
But at the moment when I use that in YALM file I get the error below:
Bamboo YAML import failed: Invalid format of the YAML file: found undefined alias stages in 'reader', line 79, column 7: <<: *stages
Can I use YAML Anchors in my bamboo specs?
Hello @[deleted] welcome to the community :)
Yes, you can use YAML Anchors in your Bamboo Specs, but with some precautions.
If I see correctly, you tried to declare stages on one document (plan) and tried to re-use the same stages on a second document (plan). Bamboo YAML Specs does not support cross-document anchors and in your case it won't work.
Alternatively, you can make the use of Includes as a workaround this limitation. You would create a separated YAML file with the definition of your stages, and then include them as the stage of both your plans.
Is that a good fit for you?
Yes, that IS a good idea.
Other question is.
I want create 2 plan in the same yalm file one for branch develop and other for Branch master.
But the problem is I put the bamboo.yml in the branch Branch master and created a linked repository for this repo and branch, but when I run the plan only clone the master and I can't clone the develop Branch.
Have any way to resolve this problem?
At the moment I create one bamboo.yml in master branch with the prod definitions and other in Develop branch with dev definitions, but if any dev make a mistake and merge the bamboo.yml from dev to master I'll have a problem
Great that it might work for you!
For the second question you will need to wait a bit more. This is a highly-requested feature that Bamboo currently doesn't support. The workaround is to maintain a plan for master and a second one for development, but in different linked repositories.
