Is there any detailed information about how to setup job requirements with exists, matches operations.
I am trying to use the bamboo yaml specs but it just can't see the requirement being set
here is my
project:
key: IT
plan:
key: CIINF
stages:
- jobs:
- scripts:
- echo 'Going to slay the red dragon, watch me'
- sleep 1
- echo 'Nailed it'
requirements:
- system.builder.command.DotNet
The above code does not detect any agents with the above capability but there are. What am I missing?
Do you mean that the requirement isn't set at Plan Configuration > Stages & jobs > Job 1 > Requirements tab ?
Or is it showing no agent able to build it?
The capability is case sensitive. Check if the capability configured for the agent have the same case "DotNet" or it have different Capital Letter.
