×Hi Team,
We have below 2 tasks in "BUILD plan" in Bamboo 9.2.10 , and after this build execution, it has to pass "release number" to "deployment plan". But on Build plan execution, it is gong to queue for longer time because it is trying to connect a bitbucket "http://bitbucket.appz.com" , which is not past of the build tasks execution.
Task(1):create a properties file:-
echo pom.releaseVersion=${bamboo.proj.build.releaseVersion} > "workflow-listener.properties"
echo pom.artefactId=hello-world-service >> "workflow-listener.properties"
echo AppZ_anypoint_mule_version=3.8.4 >> "workflow-listener.properties"
more workflow-listener.properties
Task(2): Inject bamboo.proj.build.releaseVersion for deploy plan
Path to properties file(required)
Relative to the build's working directory.
Namespace(required)
proj
Namespace is used to avoid name conflicts with existing variables.
Scope of the variables
Local
Variables will only be available in this job.
Result
But while build is executing , it is going to Queue for longer time , and in logs I found below error.
Logs:-
process for build 'Retail Transformation - hello-world-service-uat - Default Job #27 (RT-HEW1UAT-JOB1-27)'\n ... running command line: \n/anw/bamboo/application-data/temp/RT-HEW1UAT-JOB1-27-ScriptBuildTask-1426818369492427374.sh\n ... in: /anw/bamboo/application-data/local-working-dir/3145729/RT-HEW1UAT-JOB1\n
2024-02-20 07:25:20,562 INFO [NavLink RestCapabilitiesClient:thread-1] [RetryExec] I/O exception (java.net.SocketException) caught when processing request to {s}->https://bitbucket-test.appD.com:443: Connection reset
2024-02-20 07:25:20,562 INFO [NavLink RestCapabilitiesClient:thread-1] [RetryExec] Retrying request to {s}->https://bitbucket-test.appD.com:443
2024-02-20 07:27:18,451 INFO [RemoteEvents CapabilitiesCacheLoader:thread-1] [RetryExec] I/O exception (java.net.SocketException) caught when processing request to {s}->https://bitbucket-test.appD.com:443: Connection reset
2024-02-20 07:27:18,451 INFO [RemoteEvents CapabilitiesCacheLoader:thread-1] [RetryExec] Retrying request to {s}->https://bitbucket-test.appD.com:443
2024-02-20 07:27:39,124 INFO [18-BAM::CD Agent::Agent:pool-31-thread-1] [BuildAgentControllerImpl] Agent 17006593 checking build queue for executables...
Please help me how to resolve this error.
Thank you,
Dev G
Hello @Devendar Gangapuram
From your description, it seems like you're having issues with your Bamboo build plan getting stuck in the queue for a long time. This is happening because it's trying to connect to a Bitbucket server at `http://bitbucket.appz.com`, which isn't part of your build tasks execution. From the logs that you have provided, it seems that a service is trying to connect to a Bitbucket repository located at `https://bitbucket-test.appD.com:443`
We looked at the script you sent, and it appears you used more command to display the content of the file. I think this is because the "more" command is executing the script task repeatedly. Kindly see whether using the "cat" command solves the problem.
cat workflow-listener.properties.
Are the error logs you sent from the same build as well? If yes please follow below :
Or if you are connecting to another Bitbucket server you need to manually update your repositories in Bamboo to get the new SSH Base URL. If you have too many repositories to manually update, you can use the workaround on the below feature request to update them in bulk via a SQL query on your Bamboo database:
Khushboo Gupta
