×Hi all, I have a question regarding bamboo agent licenses. If i buy 5 agent licenses, can i split licenses between 2 servers ? Say, I want to use 4 licenses for test server and 1 license for production environment.
Hi Kazi,
No, you cannot have two instances running with the same SEN. For your test instance, you may however generate and use a developer license by following these steps:
Hope that helps.
Jey
