Bamboo not starting on fresh express installation
Jesus Lopez
August 25, 2020
Hello guys,
Im having an issue when starting the new  fresh installation of bamboo, basically I have the following error:
2020-08-25 09:46:58,526 WARN [C3P0PooledConnectionPoolManager[identityToken->2rvxtzaca9pugx6uzy77|76b5f2ae]-HelperThread-#0] [ThreadPoolAsynchronousRunner] An Error forced the closing of Thread[C3P0PooledConnectionPoolManager[identityToken->2rvxtzaca9pugx6uzy77|76b5f2ae]-HelperThread-#0,5,main]. Will attempt to reconstruct, but this might mean that something bad is happening.
java.lang.ExceptionInInitializerError
at com.ibm.icu.text.Collator.<clinit>(Collator.java:946)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at org.h2.value.CompareMode.<clinit>(CompareMode.java:57)
at org.h2.engine.SessionRemote.<init>(SessionRemote.java:95)
at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:116)
at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:100)
at org.h2.Driver.connect(Driver.java:69)
at com.mchange.v2.c3p0.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:175)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:220)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:206)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool$1PooledConnectionResourcePoolManager.acquireResource(C3P0PooledConnectionPool.java:203)
at com.mchange.v2.resourcepool.BasicResourcePool.doAcquire(BasicResourcePool.java:1138)
at com.mchange.v2.resourcepool.BasicResourcePool.doAcquireAndDecrementPendingAcquiresWithinLockOnSuccess(BasicResourcePool.java:1125)
at com.mchange.v2.resourcepool.BasicResourcePool.access$700(BasicResourcePool.java:44)
at com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask.run(BasicResourcePool.java:1870)
at com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread.run(ThreadPoolAsynchronousRunner.java:696)
Caused by: java.lang.IllegalArgumentException: Invalid version number: Version number may be negative or greater than 255
at com.ibm.icu.util.VersionInfo.getInstance(VersionInfo.java:191)
at com.ibm.icu.impl.ICUDebug.getInstanceLenient(ICUDebug.java:65)
at com.ibm.icu.impl.ICUDebug.<clinit>(ICUDebug.java:69)
... 17 more
2020-08-25 09:46:58,526 WARN [C3P0PooledConnectionPoolManager[identityToken->2rvxtzaca9pugx6uzy77|76b5f2ae]-HelperThread-#2] [ThreadPoolAsynchronousRunner] An Error forced the closing of Thread[C3P0PooledConnectionPoolManager[identityToken->2rvxtzaca9pugx6uzy77|76b5f2ae]-HelperThread-#2,5,main]. Will attempt to reconstruct, but this might mean that something bad is happening.
java.lang.NoClassDefFoundError: Could not initialize class org.h2.value.CompareMode
2020-08-25 09:46:58,526 WARN [C3P0PooledConnectionPoolManager[identityToken->2rvxtzaca9pugx6uzy77|76b5f2ae]-HelperThread-#1] [ThreadPoolAsynchronousRunner] An Error forced the closing of Thread[C3P0PooledConnectionPoolManager[identityToken->2rvxtzaca9pugx6uzy77|76b5f2ae]-HelperThread-#1,5,main]. Will attempt to reconstruct, but this might mean that something bad is happening.
I don't really know how to fix it. But it loops on the installation of the DB. Could you please help me? Thanks a lot
Alexey Chystoprudov
August 25, 2020
It's issue related to Java version, please use 1.8u250 and below, versions 1.8u254+ cause overflow at H2 DB, see https://jira.atlassian.com/browse/BAM-21018
Another solution is to use non embedded DB like PostgreSQL or use Bamboo 7.1.1+
