Bamboo onDemand Stash integration
IgorYastrebov
Stash commit should show build information like here: https://confluence.atlassian.com/display/BAMBOO/Integrating+Bamboo+with+Stash
I read a bunch of articles around this issue. Nothing help.
Bamboo Stash plugin is enabled, I can configure bamboo notification to Stash but a warning says about some app link issue; like this: https://jira.atlassian.com/browse/BAM-13876
Application links are established between Bamboo/Stash though.
Can anybody help?
IgorYastrebov
bamboo 5.6 is released on demand 2 weeks ago. No progress with the original issue sad still do not see a Basic auth from bamboo app link.
IgorYastrebov
so, waiting for Bamboo 5.6 on Demand
cbenard1
June 8, 2014
Hi Igor,
The workaround for this issue as mentioned here:
https://confluence.atlassian.com/display/BAMKB/Bamboo+build+results+not+published+to+stash+and+an+NPE+is+thrown
unfortunately does not apply to the OnDemand platform as there is no ability to change the authentication type for Application Links. The only option is to wait for the bug to be resolved in Bamboo 5.6, so you should see it in one of the next releases.
My apologies that we do not have a better solution than this at the time, but please add your comments to https://jira.atlassian.com/browse/BAM-13876and become a watcher in order to receive immediate updates.
Turner
Mikhail Turalenko
January 27, 2015
according to https://confluence.atlassian.com/display/BAMBOO/Integrating+Bamboo+with+Stash
"Note that the legacy Stash notification type is deprecated – it is still available in Bamboo 5.6 but will be removed in Bamboo 5.7."
so everything should work without it i assume. but still not. i have created related question with a few suggestions https://answers.atlassian.com/questions/12161578
atlassian, opsgenie migration, jira service management, incident response, on‑call management, alerting tools, migration guide, devops operations, service reliability, atlassian learning, migration best practices, opsgenie support, IT operations
Join the Opsgenie Migration group 🚚
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
