Bamboo planbranch setting to prevent deletion pendant in database
HeWi May 16, 2022
I wonder where in the Bamboo database the setting "Clean up plan branch automatically" is stored while creating a new planbranch?
(see 2b: https://confluence.atlassian.com/bamboo/using-plan-branches-289276872.html)
Is it maybe stored in a local database or xml file instead? The scheduler will not delete planbranches having the option deactivated and I would like to understand how Bamboo does make a decision between different plan branches.
Eduardo Alvarenga
May 16, 2022
Hello @HeWi
The Plan branch cleanup is defined on the BUILD_DEFINITION table in the database as an XML element within XML_DEFINITION_DATA.
<cleanup><disabled>true</disabled></cleanup>
This query might help you locate that information. Works on PostgreSQL.
SELECT B.BUILD_ID,
       B.BUILD_TYPE,
       B.FULL_KEY,
       BMD.BRANCH_NAME AS "branch_name",
       CASE
              WHEN CAST((XPATH('//branchConfiguration/cleanup/disabled/text()',CAST(BD.XML_DEFINITION_DATA AS XML)))[1] AS TEXT) = 'true' THEN 'NO'
              ELSE 'YES'
       END AS BRANCH_CLEANUP
FROM   BUILD B
JOIN   BUILD_DEFINITION BD
ON     B.BUILD_ID = BD.BUILD_ID
JOIN   BRANCH_METADATA BMD
ON     BMD.PLAN_ID = B.BUILD_ID
WHERE  B.BUILD_TYPE = 'CHAIN_BRANCH'
Eduardo Alvarenga
Atlassian Support APAC
HeWi May 19, 2022
Ahh, I see, thanks a lot for your reply @Eduardo Alvarenga , very helpful indeed.
Looking at the column with ntext datatype, it is kind of laborious, if the switch would have to be toggled, I would have to work with temporary tables, doing casting, etc.
Isn't there a simpler way in Bamboo to avoid specific plan branches from getting cleaned up automatically (I don't want to uncheck the planbranches manually)? I have to take two options into consideration:
a) cleanup due to git delete branch
b) cleanup due to branch inactivity
What if I would like to avoid bugfix/ branches from getting cleaned up? Is the only chance to look for bugfix/ branches in the tables and set disabled to true in the XML?
Eduardo Alvarenga
May 19, 2022
Hey @HeWi
Thanks for the feedback. Following the community guidelines please avoid posting different concerns as a follow-up to a question that's been already answered.
If you are satisfied with the first answer please mark it as Accepted and post the next question as a second post and we'll be happy to assist. That eases the web crawler job and enhances indexing (and search) to other users.
Eduardo Alvarenga
HeWi May 19, 2022
Hello @Eduardo Alvarenga , thanks for your reply and guideline reference. I've followed your suggestion and created another thread: Way to stop automatic planbranch cleanup for specific branch types
