×I have a plan branch that has been running 300+ times. Recently when this plan is executed it stops immediately, it has no logs, it self-disables, it is not in the "recent build list" and does not show an error to the administrator. I've restarted the agent with no success. If I run the commands manually as the user that runs the agent, the process works. I've used Bamboo for 10+ years and never had this level of "no info" from a build failure before. What else should I try?
Hello Mark,
Welcome to Atlassian community.
Are you able to see any logs inside <bamboo-home>logs>atlassian-bamboo.log file related to this plan when it is triggered, it will give some hint regarding the problem.
Shashank Kumar
