Hello.
I am building an ASP.NET web site using command line, with Visual Studio msbuild, like this:
/p:DeployOnBuild=true /p:WebPublishMethod=Package /p:PackageAsSingleFile=true /p:SkipInvalidConfigurations=true;PackageLocation=${bamboo.build.working.directory}
It works ok (it creates a deploy.cmd and a zip file in my build working directory).
In my deploy task, I also used command line and define my task like this:
msdeploy -verb:sync -source:package="ASPSample.zip" -dest:auto -setParam:kind=ProviderPath,scope=contentPath,value="Default Web Site"
In here something is going on because my Deploy keeps going for a while... I think it's some issue about the working directory, because if I use this commands in the command line (by hand) everything is working fine.
So, my question is this: what's the better solution for fixing this? (Making the deploy fetching the same directory where my build is).
Thanks.
Hi @Fr0zt if you are using deploy task on a Deployment proyect the firt step is download the artifact second one the path for "ASPSample.zip" must be absolut path you must combine the working directory + ASPSample.zip.
Cheers.
