Build parameters for Bamboo
Areg Vrtanesyan _Work_
Hi all
I am wondering if anyone else has tried to build parameters form for Bamboo plan?
Jenkins with "Configuration as a code", "Build with parameters" and other plugins allows to create pipeline data input form which allows to enter or choose parameters for the build. It also allows to run scripts to populate dynamic form data like select lists using variouss scripts.
Has anyone tried to find similar functionality?
Areg
