Hi!
I'm having issues with doing Git push for both tags and commits when using a cached repository setup in Bamboo.
The scenario:
We are using a child plan that builds our application. During the bild we generate files and create tags. Both pushing the commits and the tags seem to work (no errors), but never show up in the logs at the remote (Stash). Found this in the logs:
build 08-Nov-2013 12:51:13 version DONE pushing commit build 08-Nov-2013 12:51:13 tagging ################################################################# build 08-Nov-2013 12:51:13 tagging Starting tagging build 08-Nov-2013 12:51:13 tagging build 08-Nov-2013 12:51:13 tagging -*- EXECUTING: git tag -a -mAuto-Release-Build-b-feature-feature-DEV-10171-update-build-script-to-use-alternative-4-based-on-feature/DEV-10171-update-build-script-to-use-alternative b-feature-feature-DEV-10171-update-build-script-to-use-alternative-4 build 08-Nov-2013 12:51:13 tagging build 08-Nov-2013 12:51:13 tagging DONE creating vcs tag b-feature-feature-DEV-10171-update-build-script-to-use-alternative-4 build 08-Nov-2013 12:51:13 tagging build 08-Nov-2013 12:51:13 tagging -*- EXECUTING: git push --tags build 08-Nov-2013 12:51:13 tagging error 08-Nov-2013 12:51:13 To file:///opt/atlassian/application-data/bamboo-agent/xml-data/build-dir/_git-repositories-cache/1c07087b9ce946f558f8dfc5679a2dbd3342378b error 08-Nov-2013 12:51:13 * [new tag] b-feature-feature-DEV-10171-update-build-script-to-use-alternative-4 -> b-feature-feature-DEV-10171-update-build-script-to-use-alternative-4 build 08-Nov-2013 12:51:13 tagging DONE pushing tag
The line with "To file://..." caught my eye. To me it looks like the push is done to the cache, and not to the actual remote.
So my question is this, is there a way to bypass/specify not to use the cache when pushing?
We had what I think is a similar issue and the instructions in https://confluence.atlassian.com/display/BAMKB/Merging+and+pushing+to+remote+repository+fails did help us.
Have you tried specifying repository url? as in: git push <options> [repositoryUrl]
See also: https://www.kernel.org/pub/software/scm/git/docs/git-push.html
You can get repository url from variable: ${bamboo.planRepository.<repositoryNumber>.repositoryUrl}
where repositoryNumber is position of the repo in plan's repository list. (you can omit this for default repository)
