Can a Bamboo remote agent be on a remote network separate from that running Bamboo
yogesh_devi
December 3, 2020 edited
Helli,
I am running a Bamboo server version 7.1.1 build 70117 - 23 Jul 20.  We expect the Bamboo server to run on public cloud . We use remote agents.
My question is can we use a remote agent that is running in our on-premise lab connecting to Bamboo running on Public cloud
 Or in other words can the Bamboo server and the remote agent be on two  separate networks that are geographically separated ?
If yes, is there a documented process to do this
Jeyanthan I
December 3, 2020
Hi @yogesh_devi ,
Of course, you can have agents and server on different networks. Bamboo server and agents need 2 ports to talk to each other. I can share the ports that need to be opened for it to work fine and you can decide how to configure in your setup.
  • Port of the Bamboo itself: 8085 by default and when no proxy is used.
  • Port of the broker: 54663 by default. You'll find the full broker url in the Bamboo admin panel (System -> General Configuration)
The traffic between agent and server is bi-directional, initial connections are only sent from agent to server. Responses are sent from server to agent. For more info check this page:
Jey
yogesh_devi
December 7, 2020
Hi Jey - Thanks a lot for your prompt response
Like • Jeyanthan I likes this
