×Security scanners are finding issues with a certificate being used for port 9090 (clustering mode) can cluster-node.properties and or port 9090 be deleted on single node installations
Hello @Steven Brannan,
Bamboo will listen to port 9090 and have a cluster-ready environment by design. There is no way to explicitly disable such feature.
If you would like to disable such behaviour, you'd have to block incoming traffic on port 9090 on your server by using a firewall or network filter rules.
Eduardo Alvarenga
Atlassian Support APAC
--please don't forget to Accept the answer if the reply is helpful--
Thank you. That is what I suspected. I will have the port blocked.
