I am trying to connect a remote agent to bamboo version 6.0.2. I have downloaded the agent jar from bamboo and run the installation. But, when I start it hangs on this line:
INFO [AgentRunnerThread] [AgentRegistrationBean] Registering agent on the server
When I turn on debugging I get constantly repeated:
send a packet PING : ping
Received a packet PING : ping
Send a packet PING : ok
read a packet PING : ok
Got ping response from JVM
On the bamboo server I see these log messages:
Agent with fingerprint '7449997491164312190' has started loading
Agent with fingerprint '7449997491164312190' is now receiving its classpath
Sending 0 jars, asking to remove 0 jars
Agent with fingerprint '7449997491164312190' has finished loading
About to checkOfflineAgents...
Grace period of around 0s
Finished checkOfflineAgents took 809.0 μs
Any ideas on what the problem might be?
I figured it out. the problem was the address in the broker url had /// instead of // after tcp. Thanks to Cristiano and everybody else who thought about it.
Hi Josh! How are you doing?
In my installation, when agents don't start, I usually check:
- Lack of permission for user running agent in agent home directory
- Firewall block on ports 8085 or 54663
A full list of troubleshooting tips is here: https://confluence.atlassian.com/bamkb/troubleshooting-remote-agents-216957427.html
Hope this helps!
Cristiano
Hi Cristiano, thanks for the response. I have tried those things run as root and removed the firewall with no luck. I have gone thorugh the troubleshooting as well with no luck. Is there a particular log file that I can post that might be more helpful?
