Change bamboo.home does not work
Carsten Horlacher
April 24, 2018
somehow in the past the bamboo.home variable was set to the same directory (ISS/BAMBOO) than the application was installed. So we tried to change it but we had no luck. What we did:
Stop Bamboo (running on sles)
moved XML-DATA, artifacts, logs, backups, index and temo to /ISS/BAMBOO-DATA
Changed the variable in bamboo-init.properties
Started Bamboo
Now the setup wizard comes up! What was wrong?
Thanks in advance,
Carsten
Daniel Wester
April 24, 2018
Make sure to move the bamboo.cfg.xml as well. If you do a clean installation of the app on another area - you can see which files/directories should be moved.
rsperafico
April 24, 2018
Hi @Carsten Horlacher,
bamboo-init.properties is to define where <bamboo-home> will be, however, in the same way you can specify the directory path to Artifacts during Bamboo's installation through the UI, post Bamboo installation you will find <bamboo-home>/bamboo.cfg.xml in which describe where files are stored:
  <properties>
    <property name="bamboo.artifacts.directory">${bambooHome}/artifacts</property>
    <property name="bamboo.config.directory">${bambooHome}/xml-data/configuration</property>
So if you want to copy Artifacts and place them outside <bamboo-home> directory, you should update <bamboo-home>/bamboo.cfg.xml providing the correct path for it. The same applies to the other properties.
Rafael
