Copying build artifacts to external location
Dev July 19, 2015
Please suggest on how can we create a task to copy build artifacts to some directory on corporate network or to Nexus. So far I have to task in a Job i.e.
  1. Source Code Checkout
  2. MSBuild
I want to copy the build output to some network location. I know I can write some script to copy it to target directory but whats the source location. Where does Bamboo copy the build output?
3 votes
Mike Friedrich
July 20, 2015
You can use the Artifact Download task and the copy it with a Script task afterwards.
Or you copy it right after your MSbuild task.
You do not need to know the source location, that folder can change anyway. Simply use relative paths:
:: assumes you created an zip artifact in prev. tasks
copy /y /z workdirsubfolder\myartifact.zip \\server\share\folder
So, either you run this right after you created the artifact or you use Artifact Download before.
Note: We have the agents running under a windows service account, that way we do not need to type passwords in the task. Instead, we give that service user write access to some network locations.
