Could not use License
Jon-Patric Ewelt
October 13, 2018
When I insert my license and click Next, I get the message that this license is not valid. But I copied it directly from MyAtlassian. In the bamboo log is the INFO available:
2018-10-13 11:26:30,890 INFO [http-nio-8085-exec-11] [LicenseEditionPropertyTransformer] License type 'null' can not be resolved. This is a potentially corrupt license.
redgateway_reps October 13, 2018
Atlassian broke bamboo licensing, because they use License (version 3), but bamboo supports License version 2 ... and doesn't want to fix it ...
Jon-Patric Ewelt
October 14, 2018
And what can I do now?
Deleted user October 14, 2018 edited
I have the same problem when I try to generate a license for my bamboo instance and I've also opened a ticket, here's the link: https://community.atlassian.com/t5/Bamboo-questions/Bamboo-Trial-license-The-license-key-you-entered-was-invalid/qaq-p/914877
Chris Berry
October 14, 2018
Hi all
We are currently having an issue creating valid eval licenses.
I have contacted the group responsible and they are working on a fix.
You should be able to generate valid licenses shortly.
I'll update once they have fixed the issue.
thanks
Chris
Atlassian support- Bamboo
Chihara
October 15, 2018
Same problem with Bamboo 6.7 EAP (6.7-rc2)
Chris Berry
October 15, 2018
Hi all,
Eval licenses are now correctly generated. Please try regenerating licenses and let us know whether there are any further issues. New paid licenses should also be generated correctly.
thanks
Chris
