DeploymentTimingPoints.ExecutionCancelled event not fired
Diana Antohi
May 2, 2019 edited
I am trying to develop a Bamboo plugin. I am using Bamboo 6.8.0 build 60803 - 30 Jan 19.
This plugin needs to add functionality when stopping a deployment. In order to achieve this, I have created a listener, waiting for 'DeploymentTimingPoints.ExecutionCancelled' events.
However, this kind of events never arise.
I am able to catch other events, like: DeploymentTimingPoints.ExecutionStarted, DeploymentTimingPoints.ExecutionFinished.
Question: is bamboo actually firing 'DeploymentTimingPoints.ExecutionCancelled' when stopping a deployment?
Note: When stopping a deployment, I am receiving a process exception.
[INFO] [talledLocalContainer] 2019-05-02 15:13:48,306 INFO [http-nio-6990-exec-6] [DefaultStopBuildManager] Stopping deployment 3342337-3407873-3866627 on agent 131073
[INFO] [talledLocalContainer] 2019-05-02 15:13:48,306 INFO [http-nio-6990-exec-6] [DefaultStopBuildManager] Deployment 3342337-3407873-3866627 will be checked for termination at Thu May 02 15:14:48 CEST 2019
[INFO] [talledLocalContainer] 2019-05-02 15:13:48,307 INFO [http-nio-6990-exec-6] [DefaultBuildAgent] Cancel build request for '3342337-3407873-3866627' received on agent 'Default Agent'.
[INFO] [talledLocalContainer] 2019-05-02 15:13:48,307 INFO [http-nio-6990-exec-6] [DefaultBuildAgent] Interrupting task com.atlassian.bamboo.build.pipeline.tasks.ExecuteBuildTask@40215ab2.
[INFO] [talledLocalContainer] 2019-05-02 15:13:48,308 WARN [18-BAM::Default Agent::Agent:pool-33-thread-1] [LatchedRunnable] Interrupted waiting for ExternalProcess pump to complete
[INFO] [talledLocalContainer] 2019-05-02 15:13:48,313 INFO [18-BAM::Default Agent::Agent:pool-33-thread-1] [TaskResultBuilder] 3342337-3407873-3866627: Failing task since return code of [/home/repositories/plugin-test/target/bamboo/home/temp/3342337-3407873-3866627-ScriptBuildTask-8834092675444552255.sh] was 143 while expected 0
[INFO] [talledLocalContainer] 2019-05-02 15:13:48,313 INFO [18-BAM::Default Agent::Agent:pool-33-thread-1] [TaskResultBuilder] Process exception:
[INFO] [talledLocalContainer] com.atlassian.utils.process.ProcessException: Interrupted while waiting for process to finish
[INFO] [talledLocalContainer] at com.atlassian.utils.process.ExternalProcessImpl.handleProcessInterrupted(ExternalProcessImpl.java:500)
[INFO] [talledLocalContainer] at com.atlassian.utils.process.ExternalProcessImpl.finish(ExternalProcessImpl.java:156)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.process.ProcessServiceImpl.executeExternalProcess(ProcessServiceImpl.java:200)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.process.ProcessServiceImpl.executeExternalProcess(ProcessServiceImpl.java:210)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.plugins.shell.task.AbstractShellBuildTask.execute(AbstractShellBuildTask.java:48)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.plugins.script.task.ScriptBuildTask.execute(ScriptBuildTask.java:68)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.task.TaskExecutorImpl.lambda$executeTasks$3(TaskExecutorImpl.java:319)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.task.TaskExecutorImpl.executeTaskWithPrePostActions(TaskExecutorImpl.java:252)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.task.TaskExecutorImpl.executeTasks(TaskExecutorImpl.java:319)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.task.TaskExecutorImpl.execute(TaskExecutorImpl.java:112)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.build.pipeline.tasks.ExecuteBuildTask.call(ExecuteBuildTask.java:73)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent.executeBuildPhase(DefaultBuildAgent.java:203)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent.build(DefaultBuildAgent.java:175)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.v2.build.agent.BuildAgentControllerImpl.lambda$waitAndPerformBuild$0(BuildAgentControllerImpl.java:131)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.variable.CustomVariableContextImpl.withVariableSubstitutor(CustomVariableContextImpl.java:185)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.v2.build.agent.BuildAgentControllerImpl.waitAndPerformBuild(BuildAgentControllerImpl.java:125)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent$1.run(DefaultBuildAgent.java:126)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:48)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:26)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:17)
[INFO] [talledLocalContainer] at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:41)
[INFO] [talledLocalContainer] at java.lang.Thread.run(Thread.java:748)
