Differences between "Restricted Admin" and "Admin" Global permissions
Jeff Behl
What's the difference between these two level of global permissions?  In the documentation I find, well...let's just call it less-than-precise information:
"Restricted admin - perform some administration operations and view all plans in Bamboo"
"some" is rather nebulous.  Thanks
Max Blackmer August 17, 2018
Below is and excerpt from (https://confluence.atlassian.com/bamboo/bamboo-permissions-369296034.html)
  • Restricted admin - perform some administration operations and view all plans in Bamboo; this role excludes permissions that directly influence the host on which the Bamboo Server is located, however, all plan administration and agent administration is available to restricted admins.
  • Admin - perform all operations and view all plans in Bamboo.
A Restricted admin can work with all plans but can not change host impacting changes. (i.e. can't install plugins or change system settings for the Bamboo.)
Michał Ciania January 4, 2016
https://confluence.atlassian.com/display/BAMBOO056/Global+security+and+permission+properties
here may be the answer:
The Restricted Administrator Role global permission is equivalent to the Admin global permission but has the following restrictions:
  • Local agents cannot be created because Atlassian Cloud only uses elastic agents.
  • Users and groups are managed by Atlassian Cloud.
Jeff Behl
Thanks, but I wasn't clear: this is for an on-premise installation, not cloud
Learn more
