Sometimes, seemingly randomly, running a build in Bamboo fails.
Build jobs/stages are run inside docker, failure seems to be coming randomly, regardless of agent (most of the time it succeeds in all agents, sometimes fails in any/some agents that have built it successfully before and do build successfully after.
Log snippet from failing build:
simple 13-Sep-2023 14:59:19 Creating local git repository in '/home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/.git'.
simple 13-Sep-2023 14:59:19 /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/.git: Permission denied
error 13-Sep-2023 14:59:19 Cannot fetch branch '(unresolved) HashAndSource{refName=[null], branch=[bugfix/TEST-6503], hash=[36d68f0c4f89937ef79615144625d2c23181af06]}' from 'ssh://git@git.theserver.org:7999/mwun/gnsslocation_ts.git' to source directory '/home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6'. command [/usr/bin/git init] failed with code 1. Working directory was [/home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6]., stderr:/home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/.git: Permission denied
simple 13-Sep-2023 14:59:19 Warning: failed to checkout source code to directory '/home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6', trying to recover...
simple 13-Sep-2023 14:59:19 Cleaned source directory '/home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6'...
simple 13-Sep-2023 14:59:19 Initialized empty Git repository in /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/.git/
simple 13-Sep-2023 14:59:19 Fetching 'refs/heads/*' from 'ssh://git@git.theserver.org:7999/example/project.git'.
simple 13-Sep-2023 14:59:19 Warning: Permanently added '[127.0.0.1]:38017' (RSA) to the list of known hosts.
simple 13-Sep-2023 14:59:19 From ssh://127.0.0.1:38017/example/project
simple 13-Sep-2023 14:59:19 * [new branch] TEST-2100 -> TEST-2100
simple 13-Sep-2023 14:59:19 * [new branch] TEST-2285 -> TEST-2285
simple 13-Sep-2023 14:59:19 * [new branch] TEST-2648 -> TEST-2648
simple 13-Sep-2023 14:59:19 * [new branch] TEST-2652 -> TEST-2652
simple 13-Sep-2023 14:59:19 * [new branch] TEST-2681 -> TEST-2681
simple 13-Sep-2023 14:59:19 * [new branch] TEST-292 -> TEST-292
simple 13-Sep-2023 14:59:19 * [new branch] TEST-2969 -> TEST-2969
simple 13-Sep-2023 14:59:19 * [new branch] TEST-3541 -> TEST-3541
simple 13-Sep-2023 14:59:19 * [new branch] TEST-421 -> TEST-421
simple 13-Sep-2023 14:59:19 * [new branch] TEST-437 -> TEST-437
simple 13-Sep-2023 14:59:19 * [new branch] TEST-4937 -> TEST-4937
simple 13-Sep-2023 14:59:19 * [new branch] TEST-505 -> TEST-505
simple 13-Sep-2023 14:59:19 * [new branch] TEST-5686 -> TEST-5686
simple 13-Sep-2023 14:59:19 * [new branch] example-message -> example-message
simple 13-Sep-2023 14:59:19 * [new branch] example-testing -> example-testing
simple 13-Sep-2023 14:59:19 * [new branch] bugfix/TEST-2697 -> bugfix/TEST-2697
simple 13-Sep-2023 14:59:19 * [new branch] bugfix/TEST-4744 -> bugfix/TEST-4744
simple 13-Sep-2023 14:59:19 * [new branch] bugfix/TEST-6503 -> bugfix/TEST-6503
simple 13-Sep-2023 14:59:19 * [new branch] continuous_ver_numbering -> continuous_ver_numbering
simple 13-Sep-2023 14:59:19 * [new branch] master -> master
simple 13-Sep-2023 14:59:19 * [new tag] EX_1.0.3.0 -> EX_1.0.3.0
simple 13-Sep-2023 14:59:19 * [new tag] EX_2.0.0.0 -> EX_2.0.0.0
simple 13-Sep-2023 14:59:19 * [new tag] EX_2.1.1.0 -> EX_2.1.1.0
simple 13-Sep-2023 14:59:19 * [new tag] EX_2.2.1.0 -> EX_2.2.1.0
simple 13-Sep-2023 14:59:19 * [new tag] EX_2.5.1.0 -> EX_2.5.1.0
simple 13-Sep-2023 14:59:19 * [new tag] EX_2.6.0.0 -> EX_2.6.0.0
simple 13-Sep-2023 14:59:19 * [new tag] EX_2.6.1.0 -> EX_2.6.1.0
simple 13-Sep-2023 14:59:19 * [new tag] EX_2.7.1.0 -> EX_2.7.1.0
simple 13-Sep-2023 14:59:19 Fetching to source directory '/home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6' completed, proceeding with checkout...
simple 13-Sep-2023 14:59:19 Checking out revision 36d68f0c4f89937ef79615144625d2c23181af06.
simple 13-Sep-2023 14:59:19 Switched to branch 'bugfix/TEST-6503'
simple 13-Sep-2023 14:59:19 Checkout completed, recover successful.
simple 13-Sep-2023 14:59:19 Updated source code to revision: 36d68f0c4f89937ef79615144625d2c23181af06
simple 13-Sep-2023 14:59:19 Finished task 'Source Code Checkout' with result: Success
simple 13-Sep-2023 14:59:19 Preparing artifact 'DependencyCheckArtifacts' for use at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 14:59:19 Artifact 'DependencyCheckArtifacts' prepared in 56.82 ms at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6
simple 13-Sep-2023 14:59:19 Preparing artifact 'test_report.xml' for use at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 14:59:19 Artifact 'test_report.xml' prepared in 11.09 ms at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/test_report.xml
simple 13-Sep-2023 14:59:19 Preparing artifact 'testcoverage' for use at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 14:59:19 Artifact 'testcoverage' prepared in 11.09 ms at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/testcoverage.out
simple 13-Sep-2023 14:59:19 Preparing artifact 'testoutput.json' for use at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 14:59:19 Artifact 'testoutput.json' prepared in 13.88 ms at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/testoutput.json
simple 13-Sep-2023 14:59:19 Preparing artifact 'testoutput.out' for use at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 14:59:19 Artifact 'testoutput.out' prepared in 23.07 ms at /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/testoutput.out
simple 13-Sep-2023 14:59:19 Running pre-build action: Build Log Labeller Pre Build Action
simple 13-Sep-2023 14:59:19 Running pre-build action: VCS Version Collector
simple 13-Sep-2023 14:59:19 Starting task 'Script' of type 'com.atlassian.bamboo.plugins.scripttask:task.builder.script'
command 13-Sep-2023 14:59:19 Beginning to execute external process for build 'MW-Translation layer - example - bugfix-TEST-6503 - Build Service #10 (EXAMPLE-PROJECT21-JOB6-10)'\n ... running command line: \n/tmp/runInDocker5989393067675107037.sh /home/bamboo/bamboo-agent-home/temp/EXAMPLE-PROJECT21-JOB6-10-ScriptBuildTask-5932330718185466550.sh\n ... in: /tmp\n
build 13-Sep-2023 14:59:20 Creating version file
error 13-Sep-2023 14:59:20 fatal: Unable to read current working directory: No such file or directory
error 13-Sep-2023 14:59:20 mkdir: cannot create directory 'artifacts': No such file or directory
simple 13-Sep-2023 14:59:20 Publishing an artifact: version
error 13-Sep-2023 14:59:20 Unable to publish artifact [version]: the source directory /home/bamboo/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/artifacts does not exist.
simple 13-Sep-2023 14:59:20 The artifact hasn't been successfully published after 1.210 ms
The first error ("fatal: unable to read current working directory") comes from running git tag.
As said, this seems to occur randomly, regardless of the agent that runs this job. It's as if current working directory gets removed (or removed and re-created - I'm in Ubuntu).
Most of the time it goes without problems, code snippet from a successful build:
simple 13-Sep-2023 16:02:57 Checking out into /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6
simple 13-Sep-2023 16:02:57 Updating source code to revision: 36d68f0c4f89937ef79615144625d2c23181af06
simple 13-Sep-2023 16:02:57 Creating local git repository in '/home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/.git'.
simple 13-Sep-2023 16:02:57 Initialized empty Git repository in /var/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/.git/
simple 13-Sep-2023 16:02:57 Fetching 'refs/heads/*' from 'ssh://git@git.theserver.org:7999/example/project.git'.
simple 13-Sep-2023 16:02:57 Warning: Permanently added '[127.0.0.1]:45915' (RSA) to the list of known hosts.
simple 13-Sep-2023 16:02:57 From ssh://127.0.0.1:45915/mwun/gnsslocation_ts
simple 13-Sep-2023 16:02:57 * [new branch] TEST-2100 -> TEST-2100
simple 13-Sep-2023 16:02:57 * [new branch] TEST-2285 -> TEST-2285
simple 13-Sep-2023 16:02:57 * [new branch] TEST-2648 -> TEST-2648
simple 13-Sep-2023 16:02:57 * [new branch] TEST-2652 -> TEST-2652
simple 13-Sep-2023 16:02:57 * [new branch] TEST-2681 -> TEST-2681
simple 13-Sep-2023 16:02:57 * [new branch] TEST-292 -> TEST-292
simple 13-Sep-2023 16:02:57 * [new branch] TEST-2969 -> TEST-2969
simple 13-Sep-2023 16:02:57 * [new branch] TEST-3541 -> TEST-3541
simple 13-Sep-2023 16:02:57 * [new branch] TEST-421 -> TEST-421
simple 13-Sep-2023 16:02:57 * [new branch] TEST-437 -> TEST-437
simple 13-Sep-2023 16:02:57 * [new branch] TEST-4937 -> TEST-4937
simple 13-Sep-2023 16:02:57 * [new branch] TEST-505 -> TEST-505
simple 13-Sep-2023 16:02:57 * [new branch] TEST-5686 -> TEST-5686
simple 13-Sep-2023 16:02:57 * [new branch] example-message -> example-message
simple 13-Sep-2023 16:02:57 * [new branch] example-testing -> example-testing
simple 13-Sep-2023 16:02:57 * [new branch] bugfix/TEST-2697 -> bugfix/TEST-2697
simple 13-Sep-2023 16:02:57 * [new branch] bugfix/TEST-4744 -> bugfix/TEST-4744
simple 13-Sep-2023 16:02:57 * [new branch] bugfix/TEST-6503 -> bugfix/TEST-6503
simple 13-Sep-2023 16:02:57 * [new branch] continuous_ver_numbering -> continuous_ver_numbering
simple 13-Sep-2023 16:02:57 * [new branch] master -> master
simple 13-Sep-2023 16:02:57 * [new tag] EX_1.0.3.0 -> EX_1.0.3.0
simple 13-Sep-2023 16:02:57 * [new tag] EX_2.0.0.0 -> EX_2.0.0.0
simple 13-Sep-2023 16:02:57 * [new tag] EX_2.1.1.0 -> EX_2.1.1.0
simple 13-Sep-2023 16:02:57 * [new tag] EX_2.2.1.0 -> EX_2.2.1.0
simple 13-Sep-2023 16:02:57 * [new tag] EX_2.5.1.0 -> EX_2.5.1.0
simple 13-Sep-2023 16:02:57 * [new tag] EX_2.6.0.0 -> EX_2.6.0.0
simple 13-Sep-2023 16:02:57 * [new tag] EX_2.6.1.0 -> EX_2.6.1.0
simple 13-Sep-2023 16:02:57 * [new tag] EX_2.7.1.0 -> EX_2.7.1.0
simple 13-Sep-2023 16:02:57 Checking out revision 36d68f0c4f89937ef79615144625d2c23181af06.
simple 13-Sep-2023 16:02:57 Switched to branch 'bugfix/TEST-6503'
simple 13-Sep-2023 16:02:57 Updated source code to revision: 36d68f0c4f89937ef79615144625d2c23181af06
simple 13-Sep-2023 16:02:57 Finished task 'Source Code Checkout' with result: Success
simple 13-Sep-2023 16:02:57 Preparing artifact 'DependencyCheckArtifacts' for use at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 16:02:57 Artifact 'DependencyCheckArtifacts' prepared in 56.76 ms at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6
simple 13-Sep-2023 16:02:57 Preparing artifact 'test_report.xml' for use at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 16:02:58 Artifact 'test_report.xml' prepared in 11.50 ms at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/test_report.xml
simple 13-Sep-2023 16:02:58 Preparing artifact 'testcoverage' for use at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 16:02:58 Artifact 'testcoverage' prepared in 16.33 ms at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/testcoverage.out
simple 13-Sep-2023 16:02:58 Preparing artifact 'testoutput.json' for use at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 16:02:58 Artifact 'testoutput.json' prepared in 9.364 ms at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/testoutput.json
simple 13-Sep-2023 16:02:58 Preparing artifact 'testoutput.out' for use at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6 (location: )
simple 13-Sep-2023 16:02:58 Artifact 'testoutput.out' prepared in 8.950 ms at /home/bamboo-agent/bamboo-agent-home/xml-data/build-dir/EXAMPLE-PROJECT21-JOB6/testoutput.out
simple 13-Sep-2023 16:02:58 Running pre-build action: Build Log Labeller Pre Build Action
simple 13-Sep-2023 16:02:58 Running pre-build action: VCS Version Collector
simple 13-Sep-2023 16:02:58 Starting task 'Script' of type 'com.atlassian.bamboo.plugins.scripttask:task.builder.script'
command 13-Sep-2023 16:02:58 Beginning to execute external process for build 'MW-Translation layer - example - bugfix-TEST-6503 - Build Service #11 (EXAMPLE-PROJECT21-JOB6-11)'\n ... running command line: \n/tmp/runInDocker858592673198618565.sh /home/bamboo-agent/bamboo-agent-home/temp/EXAMPLE-PROJECT21-JOB6-11-ScriptBuildTask-5747922812257384322.sh\n ... in: /tmp\n
simple 13-Sep-2023 16:03:38 Publishing an artifact: version
simple 13-Sep-2023 16:03:38 Finished publishing of artifact Required shared artifact: [version], pattern: [version*] anchored at: [artifacts] in 12.65 ms
Any ideas what causes this and how to fix it?
We're running Atlassian Bamboo version 8.1.3 build 80110
Something happened back then when posting the question - I didn't see it anywhere so I posted a new one. Anyway, root cause for this was directory permissions gone wrong when cloning Bamboo agent.
