Sign up Log in
Error after running powershell script
Nike
I've just started to learn Bomboo. I'm trying to run job with very simply  power shell script:
$a = findstr "def" main.py
if ($a) {return 1} else {return 0}
I got errors:
/u03/atlassian/bamboo-home/temp/TB-TPC-JOB-17-ScriptBuildTask-6890328877188670307.sh: line 1: =: command not found
/u03/atlassian/bamboo-home/temp/TB-TPC-JOB-17-ScriptBuildTask-6890328877188670307.sh: line 2: syntax error near unexpected token `{return'
/u03/atlassian/bamboo-home/temp/TB-TPC-JOB-17-ScriptBuildTask-6890328877188670307.sh: line 2: `if ($a) {return 1} else {return 0}'
 What am I doing wrong?
Charlie Misonne
December 9, 2021
Hi Nikita,
Did you select powershell as interpreter in the script task configuration?
And is your Windows agent running on Windows?
Nike
Tnank you for answer.
There was problem with agent. It was running on Linux.
Like Steffen Opel _Utoolity_ likes this
Upcoming Bamboo Events
