Executable for NUnit 3 Runner
Dominic Galasso August 1, 2019 edited
Which executable do I need to create to run nunit 3 tests? It just says that I need to create an executable but does not say which.
Jack Nolddor _Sweet Bananas_
Hi Dominic,
You should have the NUnit console installed on the each agent where you would like to run NUnit tests. This executable (nunit3-console.exe) need to be manually added as a NUnit 3 type capability as well in the Bamboo UI in case the executable won't be detected by the local/remote agent itself.
Then when creating your NUnit task, you will be able to select the NUnit console from the dropdown menu as shown here:
Kind Regards
