×We have branch based build plans in bamboo. Our requirement is to run only feature branch build plan when it is committed , but for us even Integration build plan is also getting triggered along with feature build. How this can be resolved?
Hi Monica,
I would start investigating the trigger configuration in the integration build plan. If the repository is the same, you have a trigger configured to build your plan on new changes and you have that plan branch, the integration build plan will run the build.
Things to check:
Hi Daniel,
Below is the trigger configuration. Integration branch is the default branch configured to manage bamboo java-specs.
PFB, snippet of automatic branch management from planspec:
return new Plan(project(), "file-interface-handler-feature-build",
"FILEHANDLERBUILD").triggers(new BitbucketServerTrigger()).linkedRepositories("file-interface-handler")
.description("File Interface Handler Feature Build")
.planBranchManagement(new PlanBranchManagement()
.createForVcsBranchMatching("^feature/.*").delete(new BranchCleanup()
.whenRemovedFromRepositoryAfterDays(5).whenInactiveInRepositoryAfterDays(7))
.notificationForCommitters())
