When Bamboo is starting up after an update, the following messages appear, followed by nothing. Seems like the upgrade manager is stuck on task 4300. How do i fix this?
2017-03-10 15:11:08,422 INFO [localhost-startStop-1] [DefaultBootstrapManager] Running pre-bootstrap validation tasks 2017-03-10 15:11:08,500 INFO [localhost-startStop-1] [AbstractUpgradeManager] ----------------------------------------------------------------- 2017-03-10 15:11:08,500 INFO [localhost-startStop-1] [AbstractUpgradeManager] 4300 : Make sure there's single row in HIBERNATE_UNIQUE_KEY table 2017-03-10 15:11:08,500 INFO [localhost-startStop-1] [AbstractUpgradeManager] ----------------------------------------------------------------- 2017-03-10 15:11:08,571 INFO [MLog-Init-Reporter] [MLog] MLog clients using slf4j logging. 2017-03-10 15:11:08,642 INFO [localhost-startStop-1] [C3P0Registry] Initializing c3p0-0.9.5.2 [built 08-December-2015 22:06:04 -0800; debug? true; trace: 10] 2017-03-10 15:11:08,721 INFO [localhost-startStop-1] [AbstractPoolBackedDataSource] Initializing c3p0 pool... com.mchange.v2.c3p0.PoolBackedDataSource@88209804 [ connectionPoolDataSource -> com.mchange.v2.c3p0.WrapperConnectionPoolDataSource@cbabd4b8 [ acquireIncrement -> 1, acquireRetryAttempts -> 30, acquireRetryDelay -> 1000, autoCommitOnClose -> false, automaticTestTable -> null, breakAfterAcquireFailure -> false, checkoutTimeout -> 0, connectionCustomizerClassName -> null, connectionTesterClassName -> com.mchange.v2.c3p0.impl.DefaultConnectionTester, contextClassLoaderSource -> caller, debugUnreturnedConnectionStackTraces -> false, factoryClassLocation -> null, forceIgnoreUnresolvedTransactions -> false, forceSynchronousCheckins -> false, identityToken -> ******, idleConnectionTestPeriod -> 100, initialPoolSize -> 0, maxAdministrativeTaskTime -> 0, maxConnectionAge -> 0, maxIdleTime -> 30, maxIdleTimeExcessConnections -> 0, maxPoolSize -> 100, maxStatements -> 0, maxStatementsPerConnection -> 0, minPoolSize -> 0, nestedDataSource -> com.mchange.v2.c3p0.DriverManagerDataSource@425b3521 [ description -> null, driverClass -> null, factoryClassLocation -> null, forceUseNamedDriverClass -> false, identityToken -> ******, jdbcUrl -> ******, properties -> {user=******, password=******} ], preferredTestQuery -> null, privilegeSpawnedThreads -> false, propertyCycle -> 0, statementCacheNumDeferredCloseThreads -> 0, testConnectionOnCheckin -> false, testConnectionOnCheckout -> false, unreturnedConnectionTimeout -> 0, usesTraditionalReflectiveProxies -> false; userOverrides: {} ], dataSourceName -> null, extensions -> {}, factoryClassLocation -> null, identityToken -> ******, numHelperThreads -> 3 ]
Not related to this specific error.
Bamboo failed to reach the database server due to a network issue.
Restoring access to database server resolved the issue.
