Hardware requirement for Bamboo
Rupali Giri
February 20, 2013
we plan to use Bamboo for our new Development Environment that would be used for Five application deployment . We would be purchasing 5 remote agent licences. Query is , for Bamboo Server & Remote Agent Server Setup , we need to know what will be Processsor & storage requirements ?
From documentation at Atlassian site we know that it is supported on x86 based processsor but not sure how many processsor (dual , single or multi ??)
are needed for optimized performance and what will be Storage requirements if we consider 5 concurrent build agents working . (documentation says 20 GB but it is based on plan complexity ) . Please help with possible data so that we can initiate setup process.
AhmadDanial
February 17, 2014
Hey there, Rupali.
I noticed that it has been a while since you receive any response here. Have you raised a ticket in the following link:
https://support.atlassian.com
You will be able seek help from the support engineers regarding the questions that you have here. If you have not, I would kindly suggest you to do so.
Hope this helps and all the best.
