×I am trying to finish setting up Bamboo and have it connect to a SQL Database but I am getting this error?
Error accessing database: com.microsoft.sqlserver.jdbc.SQLServerException: Cannot open database "<Bamboo>" requested by the login. The login failed. ClientConnectionId:9e14b776-7543-4bce-9be9-f3e0ce4f4a9e
I gave the user db_owner and reset the password.
Hello @Michael Castro
This error only tells that Bamboo could not access the database. Do you have any firewalls blocking or different ports configured for your MSSQL?
Victor
I added an Inbound firewall rule to allow this server to talk to the server with the database.
Did it fix the connection issue?
No, we uninstalled it added more memory to the server and started over and for some reason, it worked...
How did you setup CICD for SQL Server Deployment using Bamboo ?
