How can I remove branch builds?
Shay September 13, 2013
Before I took control of my server, someone created dozens of plan branch builds. I do not see a way to remove them, just disable. I'd like to remove these to reduce clutter, can I locate and remove these on the file system to prevent them from showing up for the plan? I'm not using automated branching in bamboo. I'd like to avoid removing and recreating the plan.
roy_lyons
September 13, 2013
I created a script which generated a series of curl commands. I had to delete 40,000 of them, so my case was more interesting.... but it led me to know how to do so programatically. you increment the buildkey by 1 for each.. so i did a for loop and used the iteration number ( EASNYTEST-TESTPRODUCT${i} )
The "&save=Confirm" part is important too :)
curl -k -u username:password ! -X GET 'https://bambooserver:port/chain/admin/deleteChain!doDelete.action?buildKey=EASNYTEST-TESTPRODUCT4&returnUrl=%2Fbrowse%2FEASNYTEST-TESTPRODUCT%2FeditConfig&save=Confirm'
12 votes
Shay September 17, 2013
After working on that for a while, I found that while viewing the branch, the Actions menu has a Delete Branch option. Wish I had seen that. But I did learn some cool things from the answer above, Thanks!
jotacor October 13, 2017
Thanks. It is so intuitive...
3 votes
Jeff Keller July 16, 2014
We encountered a similar issue when Bamboo somehow created 5,000 duplicate branches plans across 6 unique plans.
Needless to say, deleting them by hand was not feasible. One of our engineers wrote a jquery script that when executed on the "configure branch plans" screen of bamboo would programatically invoke the delete URL for each branch that match the given name.
jQuery("a:contains('<branchNamePartial>')").map(function (a) {
  var a = this;
  return a.href.substring(a.href.indexOf('browse/') + 7, a.href.lastIndexOf('/'));
}).each(function (i, pk) {
  setTimeout(function () {
    jQuery.ajax({
      url: ' http://<bamboo.url>/chain/admin/deleteChain!doDelete.action?save=Confirm&atl_token=&atl_token_source=js&returnUrl=/about.action&buildKey=' + pk,
      dataType: 'text'
  }, 1);
This was against bamboo 5.4.2. Obviously this selector should be tested before running the delete function against each result. It was just run from the chrome JS console.
Shane Poage November 24, 2014
There is now some XSRF protection that prevents this from functioning. Here's a revised snippet that also refines the branch selector better as well: {code} jQuery("#config-sidebar ul.branches a:contains('<substring for branches to delete>')").map(function (a) { var a = this; return a.href.substring(a.href.indexOf('browse/') + 7, a.href.lastIndexOf('/')); }).each(function (i, pk) { setTimeout(function () { jQuery.ajax({ url: ' http://<bamboo.url>/chain/admin/deleteChain!doDelete.action?save=Confirm&atl_token=&atl_token_source=js&returnUrl=/about.action&buildKey='; + pk, dataType: 'text', type: 'POST', }) }, 1); {code}
Sam Mingolelli February 2, 2017
NOTE: This is Shane Poage's comment from one of the answers, moving it to an answer so it's easier to read.
jQuery("#config-sidebar ul.branches a:contains('&lt;substring for branches to delete&gt;')").map(function(a) {
        var a = this;
    }).each(function(i, pk) {
            setTimeout(function() {
                jQuery.ajax({
                    url: ' http://&lt;bamboo.url&gt;/chain/admin/deleteChain!doDelete.action?save=Confirm&amp;atl_token=&amp;atl_token_source=js&amp;returnUrl=/about.action&amp;buildKey='; + pk,
                    dataType: 'text',
                    type: 'POST',
            }, 1);
