How do I build an RPM using Bamboo?
John Chaney January 29, 2013
Hello, I am trying to stand up a bamboo instance and after completing a source pull and build, I would like to create an RPM for distribution to my server. Is there any information regarding how to do this or a best practice? Based on what came stock inside of Bamboo, it looks like I could do it inside of a Command Task, but I would prefer something a bit more reusable if possible.
Thank you.
-John Chaney
LucasA
January 31, 2013
Note that if you can perform on your instance command line, you can do it using Bamboo. I believe you can create a script and execute it setting a script task in Bamboo: https://confluence.atlassian.com/display/BAMBOO/Script
Lucas Lima
John Chaney March 12, 2013
This answer is definitly what I ended up implementing. The process of making RPMS is easily scritable for some sections, and needs to be configured on a per project basis in others. I suppose I was hoping for a plugin to be available, but this method will suit my needs and make me learn something new. So thanks.
AgentSmith
April 9, 2015
Chris Gembarowski
January 4, 2018
He's asking how to build an RPM packing using Bamboo not how to package Bamboo in an RPM.
David Crook
March 14, 2013
At my company we build RPMS using an ant script that calls the ant RPM task. There wasn't any difference having Bamboo run this.
