How do I select a Bamboo Remote Agent with Bamboo Specs
Paul
June 7, 2018 edited
I have had a query from one of our users who has started using Java Specs in Bamboo.  When creating a 'spec' for deployment he wants to be able to select a remote agent but can't see a way of doing this. Is this possible?
Many Thanks
Paul.
Gabriel Ribeiro
June 7, 2018 edited
Hi Paul,
One possibility is to add a custom capability to your agents and then set this capability as a job requirement.
For example, I've added a custom capability called agent with the value "agent1" to one of my agents and in my specs code I defined this capability as a job requirement:
 public Plan plan() {
final Plan plan = new Plan(new Project()
.key(new BambooKey("PROJ"))
.name("PROJECT"),
"PLANTEST",
new BambooKey("PTES"))
.stages(new Stage("Default Stage")
.jobs(new Job("Default Job",
new BambooKey("JOB1"))
.requirements(new Requirement("agent")
.matchValue("agent1")
.matchType(Requirement.MatchType.EQUALS))));
return plan;
You can do the same thing for deployment projects.
Is this a feasible solution for you?
thanks
Paul
Hi Gabriel, Many thanks for your reply, I am waiting to hear back from the user. I will get back to you as soon as I hear from them.
Kind regards
Paul
Paul
Hi Gabriel,
Just heard back and your solution worked. Thank you for your help it is very much appreciated.
kind regards
Paul
