Sign up Log in
How do we uninstall bamboo?
Charles Allison
November 27, 2015
This question is in reference to Atlassian Documentation: Installing Bamboo on Mac OS X
I installed Bamboo by mistake. How do I uninstall it?
rsperafico
November 27, 2015
Hello Charles,
Thank you for your inquire.
In order to uninstall Bamboo, please:
  1. go to <bamboo-install> directory by running the following command from Terminal:
    $ cd /path/to/&lt;bamboo-install&gt;
  2. run the following command from Terminal to stop Bamboo:
    $ ./bin/stop-bamboo.sh
    It might take a while (seconds) until Bamboo's process ends
  3. make sure the service has stopped by running the following from Terminal:
    $ ps aux | grep bamboo
    USERNAME        667   0.0  0.0  2434836    764 s000  S+    9:45PM   0:00.00 grep bamboo
    If you receive more than one entry as follow:
    USERNAME        718 144.0  1.2  4274544 101324 s000  U     9:47PM   0:02.44 /Library/Java/JavaVirtualMachines/jdk1.8.0_65.jdk/Contents/Home/bin/java -Djava.util.logging.config.file=/path/to/atlassian-bamboo-5.9.7/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -XX:MaxPermSize=256m -Xms256m -Xmx384m -Djavax.net.debug=info  -Djava.endorsed.dirs=/path/to/atlassian-bamboo-5.9.7/endorsed -classpath /path/to/atlassian-bamboo-5.9.7/bin/bootstrap.jar:/path/to/atlassian-bamboo-5.9.7/bin/tomcat-juli.jar -Dcatalina.base=/path/to/atlassian-bamboo-5.9.7 -Dcatalina.home=/path/to/atlassian-bamboo-5.9.7 -Djava.io.tmpdir=/path/to/atlassian-bamboo-5.9.7/temp org.apache.catalina.startup.Bootstrap start
    Please 'kill' Bamboo's process:
    $ kill -9 718
    // please, notice 718 is the process where Bamboo is running and this value might change in your case
  4. go to <bamboo-install>/atlassian-bamboo/WEB-INF/classes/bamboo-init.properties and take note of 'bamboo.home' value
  5. delete <bamboo-install> directory
  6. delete <bamboo-home> directory
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
Gowse shaik January 6, 2020
how to uninstall bamboo agent, which is got showing JVM exited.
