How to change Bamboo from running in console to running as a service?
Dan Gorman November 9, 2018
When we started setting up Bamboo we were running it in console. We have recently had issues with that setup and would like it to run as a service without resetting up our configurations. I installed the service and started it. I can access the bamboo page, but when I try to access a plan I get an internal server error. I don't know if there are necessary steps to migrate it to a service or I am doing something wrong. Any advice would be very much appreciated.
Gundlupet Sreenidhi
November 9, 2018
If you are running on a Windows environment, Atlassian provides the script to setup Bamboo as a service.
If you are running on a *nix environment, check here on the process of how to setup a service.
Take a look at your Bamboo logs to identify the exact reason for the Internal Server error.
