Hi Team,
I have requirement like one source code check out with multiple branches. is there any way to do it.
Thanks in advance!!
Madhu Balineni
Hello Madhu,
Welcome to Atlassian community.
When you save a linked repository in Bamboo you save it pointing to a particular branch.
If I understand correctly your questions is about if you can checkout multiple branches of a repository in source code checkout task. You can do this with some the below steps.
1. Save all the branches which you want to checkout as a separate linked repository or plan repository or project repositories.
2. In the source code checkout below, add all the repositories which you want to checkout, use the Add repository button
Shashank kumar
**please don't forget to Accept the answer if your query was answered**
