Cheers!
I need to copy an .ear file generated in my build to a different folder in my server. The target folder's name should be equals to my project version's name.
For example: My project generates a my_project.ear. I'm building version 1.0 of my project. So I would like to have the my_project.ear file to be copied to /data/version/1.0/my_project.ear
I have tried using the script task, with no use. Can anyone help me?
Script task should work. Do you see any error when you use that?
I am using a script similar to this one:
mkdir /data/version/${project.version}
and a folder called ${project.version} is created.
if I use one of Bamboo's properties ${bamboo.buildNumber} for instance, then the created folder has its name resolved to the property value (/data/version/29, for instance)
In this doc page there are many examples on using variables but I couldn't find an example which uses project version....
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
