Sign up Log in
How to create a artifact from a build log
james_mckean
I looked here - which SEEMS to answer my question.
https://confluence.atlassian.com/bamkb/how-to-save-a-build-log-as-an-artifact-892498832.html
But I cannot get it to work.  Has anyone been able to do this?
Eduardo Alvarenga
February 9, 2024
Hello @james_mckean
Can you describe where the outlined implementation is not working for you?
Thank you,
Eduardo Alvarenga
Atlassian Support APAC
james_mckean
Following up.  The problem was my formatting of build key.  It needed to be the key for the specific job I was trying to pull the log for. Not the Plan or the Stage. It says that in the article, I just missed it.   In my case it was AB-CD-JOB1 where AB was the repo code, CD was the plan code, and JOB1 was the Job code.
I also had a typo in the artifact copy pattern.  This worked for me.  **/*.txt
Like Steffen Opel _Utoolity_ likes this
