How to enable CORS on Bamboo?
Trevor Reed March 9, 2016
I would like to take advantage of the Bamboo APIs, but when I make requests from my client application, I get a CORS error (it seems to me that CORS requests should automatically be enabled for the Bamboo API). How can I allow my origin access to the Bamboo APIs?
Andy Shinn September 9, 2016
This gave me a lot of grief. But I was finally able to figure out the magic Apache settings to solve this in an Apache proxy:
<VirtualHost _default_:443>
        ServerName yourhost
        ServerAdmin someperson@yourorg.com
        SSLEngine on
        SSLCertificateFile /etc/ssl/private/yourorg.com.crt
        SSLCertificateKeyFile /etc/ssl/private/yourorg.com.key
        SSLCertificateChainFile /etc/ssl/private/chain.pem
        SSLProxyEngine          On
        ProxyRequests           Off
        ProxyPreserveHost       On
        RewriteEngine On
        RewriteCond %{REQUEST_METHOD} OPTIONS
        RewriteRule ^(.*)$ - [ENV=PREFLIGHT:true]
        SetEnvIf Origin "^(.*)$" ORIGIN=$0
        Header always set Access-Control-Allow-Origin %{ORIGIN}e env=PREFLIGHT
        Header always set Access-Control-Allow-Credentials "true" env=PREFLIGHT
        Header always set Access-Control-Allow-Methods "POST, GET, OPTIONS" env=PREFLIGHT
        RewriteRule ^(.*)$ $1 [R=204,L]
        ProxyPass / http://host.yourorg.com:8087/
        ProxyPassReverse / http://host.yourorg.com:8087/
</VirtualHost>
This allows Apache to intercept preflight requests (that are sent as an OPTIONS request) and add some headers (only if it is an OPTIONS request) and then return a 204.
The rest of it is just enabling to CORS filter in Tomcat: https://tomcat.apache.org/tomcat-8.0-doc/config/filter.html#CORS_Filter.
matt_dolan_advantasure_com June 17, 2019
In which file, on Windows if anyone knows, should the above content be placed in?  Excluding the Tomcat CORS filter, are there any additional steps required to enable CORS for Bamboo?
Kalle Sirkesalo
Most of the stuff said in here: https://answers.atlassian.com/questions/69356
Should work in your case also.
