How to get the linked Test Set ,Test Plans of a jira issue key from bamboo ?
Sushma September 26, 2019
Hi All
When the user commits the code in the Bitbucket it will trigger the bamboo build .
My requirement is
"While building the job bamboo should be capable to run all the Tests (Test,Test Set,Test Plan ) which are linked to jira Issue.and after the build it should put the execution result(Test Execution) back to jira."
To achieve this I installed 2 Plugins :
1)Xray for jira Add-on for bamboo
With this I can import the feature file of the cucumber Test .
2)Groovy tasks for Bamboo
I want to write a script which retrieves the jira issue key from the development branch / Plan branch (feature-TM-1-addition-of-2-numbers) and then fetch teh linked Test Set,Test Plan from that jira issue.
autopop.PNGHow to auto populate Tests in the issue keys field ?
Or
is there any other way to fulfill my requirement ? please do suggestion..
Thanks in advance
Regards
Sushma
Inês Silva
October 22, 2019
Hi Sushma,
Please check our documentation regarding the Integration with Bamboo, here.
If you need further assistance, please feel free to contact us: https://jira.xpand-it.com/servicedesk/
Best regards,
Team Xray
Leandro November 7, 2019
@Inês Silva HI Ines, good morning!
I am wondering if you could help me with a few questions regarding Xray
how can I add these fields (marked in red)?I have Jira (with new GUI display) and Xray and I want to write test plan and test cases with detailed steps.
Thanks.
