How to migrate Single Bamboo project to another Instance
Bill Parlock
I would like to migrate a single Bamboo project / plans to another instance of Bamboo. The destination Bamboo instance already has projects/plans so I do not want to overwrite any of the existing projects. I have been searching for documentation but what I am coming across is moving an entire Bamboo instance to another server. I just want to move a single Bamboo project to another instance that also contains other Bamboo projects.
3 votes
Anik Sengupta
September 9, 2024
Unfortunately you cannot do selective copy/clone of the projects to new instance . Its either full or nothing.
For the single plan under a project you can may be , view the plan as specs (Edit plan configuration->View plan as specs) and use java or yaml specs to generate the new plans. Else you need to manually create those plans in the new instance
Anik Sengupta
**please don't forget to Accept the answer if your query was answered**
Bill Parlock
Thank you.
SERVER
VERSION
8.0.11
Upcoming Bamboo Events
