×i have two Bamboo pipelines Dev & Test and we have many variables defined in package.sh file on DEV pipeline,
now i need that variables for child build (TEST) pipeline -its already integrated with DEV pipeline ,so i dont knw how to get that values here to make one condition in the test pipeline script file.
In the Bamboo sites/guide there is options to add global variables in UI, bt here they are using bamboo spec concepts that options r disabled now , so i cant able add global variables manually in Bamboo Ul,
so pls tell me how to create global variables using bamboo spec concepts?
how to get that values in child pipeline?
please provide the correct logic if you have , kindly help me its very urgent..
Thanks in advance..!
Are you changing the variables? As global variables are read only. When i want to pass variables between staged i create a file with the variable and values in them in the working directory and then use the inject variables,
EG:
- script:
interpreter: WINDOWS_POWER_SHELL
scripts:
Set-Location ./${bamboo.solution}
dotnet test -c Release --logger "trx;LogFileName=${bamboo.solution}_TestResults-Build_${bamboo.buildNumber}.trx" -v q
$found = Get-ChildItem -Path . -Filter *.trx -Recurse -ErrorAction SilentlyContinue -Force
$string = "testResultsExist=false"
if($null -ne $found) {
$string = "testResultsExist=true"
$string | Set-Content "testsExist.txt"
description: UnitTest
final-tasks:
- inject-variables:
file: ${bamboo.solution}\testsExist.txt
scope: RESULT
namespace: inject
- any-task:
plugin-key: com.atlassian.bamboo.plugin.dotnet:mstest
configuration:
mstestTestResultsDirectory: '**/TestResults/*.trx'
pickupOutdatedFiles: 'false'
conditions:
- variable:
equals:
inject.testResultsExist: 'true'
