×I'm using Bamboo plan branches. These are deployed through Octopus Deploy. The latter expects a unique release number with every deploy. Bamboo offers auto incrementing for releases of regular branches but not for plan branches. This is a true pain.
The only solution I see is to have a plan-level (or higher will do too) variable that I can increment and update with every deployment. But so far I have tried:
Is any of this possible and if so: how? Or is there a better solution to my core problem?
Thanks, Pascal
Yes! I got it to work using the Variable Task add-on for Bamboo. Here's how I set it up:
Use the variable ${bamboo.release_sequence_number_for_plan_branches} in subsequent steps, e.g. in the release numbering for Octopus Deploy:
create-release --project "Test" --releaseNumber ${bamboo.alphaVersion}-alpha-${bamboo.inject.jiraIssueNumber}-${bamboo.buildNumber}-${bamboo.release_sequence_number_for_plan_branches} --packageversion ${bamboo.alphaVersion}-alpha-${bamboo.inject.jiraIssueNumber}-${bamboo.buildNumber} --ignoreexisting --server http://localhost:8090/ --apiKey ${bamboo.OctopusApiKey_Password} --releaseNotes "${bamboo.inject.jiraIssueNumber}"
