Is anyone using gradle to build ant run unit tests in Bamboo?
Gail Stewart
The only plugin I've found for Bamboo is the artifactory plugin. That plugin did no have a section asking if there would be unit tests, which is what I need. Right now when the tests fail, I don't get a report on the unit tests.
Andrew van der Westhuizen February 11, 2015
Using  Atlassian Bamboo version 5.7.2, You can make use of the JUnit Parser task.
image2015-2-11 16:48:50.png
Bob Swift
December 16, 2013
Groovy Task for Bamboo has gradle support. Perhaps that would help you.
roy_lyons
December 16, 2013
This is old... :) but I have a thought.
So you can run this as a command task or script task if you dont have artifactory
there is a junit test results collector task which you can then run right afterwards in the same job to pick up the test results and it will work just as if you had done it with maven or something.
