Is there a simple way to clear all the branches of a build plan?
Dan Rumney
I have a build plan that has accrued a bunch of branches that are old, but haven't been cleared away.
Is there an easy way to clear them all away without having to remove them manually, one by one?
Ron Chan
July 1, 2014
Are you trying to remove the branches from bamboo only or from the repository?
Dan Rumney
That's precisely what I'm trying to avoid. There are 76 of them.
Ron Chan
July 1, 2014
If you know these branches can be removed, proceed to unmark them. Btw, bamboo only removes the branch builds not the branches from your repository.
Dan Rumney
That's precisely what I'm trying to avoid. There are 76 of them, so manually deleting them, one-by-one will be lengthy and tedious.
Ron Chan
July 1, 2014
Dan,
There's a feature called "Automatically manage branches". There you can have bamboo remove branches after N days of inactivity.
Ron
Dan Rumney
Unfortunately, these branches have been marked to not be automatically removed.
